Wiring question
first off, i have a 1968 Camaro
Ok here's the problem... the old wiring harness in my car is in decent shape, minus the ignition wire coming from the firewall to the starter.
My question is, instead of replacing the ENTIRE wiring harness would it be fine to splice a line directly from the ignition switch itself to the starter? (with a fuseable link for safety) I have already found a hot line that will start the motor over, but it is a constantly hot wire in the "on" position and obviously the starter requires a wire that is only hot in the "start" position.
I have found the wire from the ignition switch to the firewall, but i believe that the guy who painted my car ripped it out the one from the firewall to the starter on accident.
Any help is great. Thanks.
~Max
