wiring (short) - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2004, 06:12 PM
wiring (short)
Hey Doc..... I was checking out short i have on my 1969 corvette and found that at the alternator there is a bracket that holds the main wire harness (The red wire hot all the time). For some reason the end of the bracket was clamped on the wire harness and had cut into it which was touching the hot wire causing the fusable liks at the BAT terminal to burn out...Thanks DOC and GUYS for all your help.......
