Wiring a Tilt Mercury Switch for Trunk Light - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 08:57 PM
I got a mercury switch to turn the trunk light on when the lid is raised. The only switch I could find has a 150mA rating for a 12 V system. I assume that wiring this inline with the light will burn it out immediately.
So, do I use a standard 30/40 amp relay activated by the mercury switch to send power to the trunk light?
John
Old 05-10-2006, 09:01 PM
docvette's Avatar
Wiki Edits: 12
John
Doc here,
How many Watt is the lamp?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-10-2006, 09:15 PM
The original bulb in the 6 V system has the marking "3W 6-8".
The car has been rewired for 12 V. What watt replacement bulb should I use in the 12 V system?
Old 05-10-2006, 09:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
!2 Volts at 3 watts..
To run it direct a max you can only run a 1.8 watt lamp or less (unless I slipped a digit in math..)That probably wouldn't be very bright at all..
So yeah, You need to cruise the local Radio Shack for a 12 volt relay with a coil draw of 150 Ma or less (or a higher amp Merc switch) and wire it for lamp operation.
wire one Fused wire from 12 Volts to one side of the Coil.
Wire another 12 volts fused wire to the Normally open contact, (Don't use the coil wire).
Then wire the other side of the coil to the merc switch and it to ground.
That should make it work.
Doc
The Center wiper will be the lamp .
Innovations
Old 05-11-2006, 02:38 AM
were you got the mercury switch ?
Old 05-11-2006, 06:10 AM
john, go to any junk yard, have them clip the under hood light out of a car, use that, $2? in the trunk
Old 05-11-2006, 11:31 AM
i really like mercury lights they are ligke magic. but i do the relay trick and i found it annoying because i got all my relays under the dash and everytime i accelerate hard the relay starts acting up sounds when i press the pedal in the 1-2 gear change when i stop .. it's getting annoying as i say. if you get the ones that already got mercury on them as redmustang says you'll eliminate the relay and the annoying sound of the relay
Old 05-11-2006, 04:06 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
CXPCMAN,
I think your talking about Mercury Vapor Lamps..If I read your post correctly..
He is talking about Mercury Switches..To control a relay to drive an Incandescent lamp.
But your post poses an Interesting Problem specific to Mercury Switches..Is the jarring movement of the switch under hard accelleration/Decel..This Would/Could Cause the relay to false Trigger unexpectedly, making all kinds of Annoying "Clicks" on the relay..
The light would be non~problematic, as it would only be on/off rapidly, and never seen in the trunk..but in a quiet vehicle the stuttering of the relay could drive you crazy..
I wonder if he took that into consideration?
Thanks for the Idea "Spark" !
Doc
Innovations
TRANny & O/D light problem on 96 mercury mystique grover805 Transmission - Rearend 9 08-25-2004 12:59 AM
1991 Honda Accord Sports Switch Light flashes mwething Transmission - Rearend 2 05-14-2003 06:14 AM
light switch jezer69 Electrical 0 11-15-2002 09:47 PM
Brake Light Switch 66chevy2ss Electrical 9 09-24-2002 12:50 PM
Old Head Light Switch tm454 Electrical 1 04-20-2002 11:14 PM
