wiring for torque convertor lockup on 700R4 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 08:32 AM
I have a 700R4 transmission from a 1987 Camaro. It is hooked up to a 1988 305 Chevrolet engine and works fine. It was just overhauled complete with a new torque convertor. I need to wire up the convertor lockup. I have a new plug for the transmission. I want to hand wire it without buying a kit. I also will need a to get a vacuum switch to kill the lockup when operating conditions call for releasing the lockup. I have a basic knowledge of how the system works, I'm just am not sure which pins to hook up to. Thanks for your help. Skyraker
Old 06-29-2011, 12:50 PM
SSedan64's Avatar
Connector>> http://www.hughesperformance.com/pdfs/HP700-R4.pdf
Diagrams>> http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Parts @bottom of Pg.>> http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
Old 07-01-2011, 07:28 PM
tcc
I would run 12V to the + side of the tcc solenoid and run the other side to the 4th gear switch for ground.
tcc will come on right on top of 4th gear but it will work
Old 07-01-2011, 08:33 PM
tnsmith10's Avatar
when will it rain???
check here
Old 07-01-2011, 10:19 PM
Crosley's Avatar
Wiki Edits: 1659
or here on Crankshaft wiki
700r4 convertor lock wiring rwa1015 Transmission - Rearend 6 11-14-2010 09:02 AM
700r4 Torque converter lockup coming on and off chevy_c10 Transmission - Rearend 4 05-04-2010 07:43 PM
700r4 torque convertor flair Bigmac26 Transmission - Rearend 5 03-25-2008 04:40 PM
700r4 torque convertor 455c-10 Transmission - Rearend 13 09-06-2005 01:28 PM
transmission fluid in torque convertor joe28boxer Transmission - Rearend 1 10-12-2003 03:47 PM
