Wiring Turn Signals On 57 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2011, 01:40 AM
NCC1701D's Avatar
GREGF
I've Got A 57 Chevy 3/4 Ton Truck And I'm Having A Frustrating Time Getting The Rear Turn Signals To Work. How Should I Tie In The Turn Signals From An External Turn Switch With Integrated 4-way Switch Running Off Of A Single "blinker Can" To My Stop/tail/turn 2-wire Rear Lights. I'm Also Using The Stock Type Brake Light Switch And Mostly Original Wiring Harness. If There's A Wiring Diagram Out There Somewhere That Covers This Please Let Me Know. I've Been Trying To Figure It Out By Myself For Two Weeks Now. Please Help!.!.
Old 04-14-2011, 12:32 PM
ogre's Avatar
the 'Duracell Project'
a good place to start is to read a painless wiring manual.
while it may not be specific to your truck, it's universal in wiring.
read thru the whole manual as there are a couple of sections for stop/turn wiring
there is a 12v brake feed and a 12v blinker feed to the blinker switch
and 4 wires out to each corner of your truck
the painless manual has diagrams for both styles of blinkers on our trucks
some 3/4t originally had separate turn signals mounted on the fenders and brake & tail lights integrated in the bed
if thats the case you will need a new blinker switch to run the brake lights thru the blinker switch
if you have a newer switch or stock one with integrated blinker/stop lights then you need to hook it up per painless.
amazingly gm never change the wire colors, the painless instruction will work for you
http://painlessperformance.com/Manuals/10101.pdf
Old 04-14-2011, 12:35 PM
ogre's Avatar
and check out
55 to 59 chevy truck owners
''we'' hang out there
Old 04-15-2011, 12:26 AM
NCC1701D's Avatar
GREGF
Thanks Ogre For The Info. It Confirmed What I Was Hoping To Avoid. Now All I Have To Do Is Get A Couple More Turn Signals And I'll Be Good To Go.
1965 chevy impala turn signals impala dreaming Electrical 5 06-28-2010 09:04 PM
Wiring For Turn Signals Seon Electrical 5 12-26-2005 01:04 AM
turn signal wiring for '82 Chevy truck jimfulco Electrical 2 10-16-2004 11:09 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 06:04 AM
turn signals impala dreaming Electrical 5 02-24-2003 07:29 PM
