This brief description of the wiring may help
GM steering column connections
White stop light switch dark green right rear stop light and turn signal yellow left rear stop light and turn signal purple turn signal flasher brown hazard flasher dark blue right front turn signal light blue left front turn signal black horn As you can see the rear directionals and brake lights run through the turn signal switch . The brown wire at the rear of the vehicle is for the taillights . The bulb sockets MUST have a good ground for everything to work . Hope this helps . |
adantessr seems to be on the right track. Check your connections on your turn signal switch to make sure they're correct, and check your grounds again at the tail of the vehicle. Good grounds can be hard to come by, so make sure they are good and clean.
When the turn signal is activated the filament that was acting as the brake light becomes the flashing turn indicator. So when the turn signal is on you will not have a brake light on that tail light. Same circuit and wire controlled by the switch in the column.
Connect the wires back up and see what is working, do this by turning on the head lights, you at least should see a tail light. If you see that then investigate the brake/turn signal circuit. If nothing at all no tail light or brake/turn that could indicate a bad ground or bad wiring. Was this ever working before you installed these tail light assemblies? |
daveid
are these stock lights or custom lights? 2 wire lights are hot and ground. good for stop/turn or tail, but not both. 3 wire lights are hot, hot and ground. they are needed for stop/turn and tail. i believe even the stock replacement lights have 3 wires to attach a good ground. if they are stock replacements and use the case as a ground and you have new paint add a ground wire. also check out the 55-59 chevy truck forum in this forum |
hmmmmm..... my taillights are two wires, 67 camaro, Stop/turn on one wire, tail light on the other and uses the socket as a ground. a standard 1157 bulb (stop/turn/tail, two filiments) socket has two notches/slots 180 degrees across from each other one will be shorter than the other
thanks for all the responses. They are new after market lights with 2 wires. The wiring is brand new and installed by my mechanic but i didnt have the lights at the time he wired it. I just went out and checked the lights again and now im getting blinkers, flashers, and lights when the headlights are on but now brake lights. The brake lights did work though a few nights ago.
Check the brake light fuse and switch . The problem has to be between the fuse panel to the column since you have directionals .
| Cruise Control Compatibility with LED's? | cboy | Electrical | 44 | 10-01-2010 12:08 PM |
| Frenching tail lights | olds37dude | Body - Exterior | 1 | 10-11-2007 08:06 AM |
| Starter Problems | Jsquier | Electrical | 5 | 08-26-2007 05:32 PM |
| LED tail lights stay partically lit | cboy | Electrical | 20 | 07-21-2007 07:59 PM |
| Wiring a 1 wire alternator and starter | 71novactb | Electrical | 7 | 02-09-2007 09:14 PM |
