wiring up a/c - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2006, 05:37 AM
1939d2/s10's Avatar
wiring up a/c
Does anyone have a link that shows a basic wiring setup for an airconditioning installation ? I have not been able to locate a schematic,thanks Johnny
Old 07-21-2006, 07:10 AM
1939d2/s10's Avatar
a/c
Anyone ??? Im pretty sure I can wing this but just wanted to double check I was in the right direction by looking at a schematic,thanks in adavnce.Johnny
Old 07-21-2006, 07:15 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Vintage Air has downloads available for their systems
That might help
What kind of unit is it---If we knew what kind, it would be more helpful
Bryan
Old 07-21-2006, 07:30 AM
1939d2/s10's Avatar
Okay,my fault.Its actually a mercedes benz.I have an intact system that when I bypass the silly (and very expensive climate control relay ) it blows cold air.I bought an aftermarket capillary temp control swith from oldair products down in Texas.My plan is to install the capillary in to the evaporator,run 12v to the capillary temp control then run the other side of the of the switch to the now removed a/c relay (190 us dollars) I think I will have no problem basically the new a/c switch temp control will take place of the relay and give temp control and power to the a/c clutch.The low temp /high press cutout and fan control is in series after the relay so that is still intact giving me my factory safetys and cutouts.How does all this sound ?I think it will work fine just wanted to look at a basic schematic to verify I hadnt missed anything,would appreciate any input you could share,thanks Johnny
Old 08-08-2006, 08:03 PM
75gmck25's Avatar
I'd take a look at the info in the forums on www.ackits.com.
The wiring is a little different depending on what type of A/C setup you have. On my '75 Chevy with a Cycling Clutch Orifice Tube system, the A/C controls on the dash send power through the AC low pressure switch and through the temp sensor in the evaporator. If the AC pressure is above about 35 psi and the temp sensor is above about 35 degress, it turns the compressor on. The temp sensor in the evaporator cycles the compressor on and off to keep the evaporator from icing up. The temp control in the dash just mixes cold air from the evaporator with warm air from the heater core to adjust the temp.
Bruce
To leave or keep A/C chevyguy General Rodding Tech 13 08-14-2010 04:06 PM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
A/C condensation pump wiring? akm Garage - Tools 2 04-04-2006 03:18 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
A/C question Paco Engine 1 06-03-2002 07:01 PM
