wiring up a efan with relays? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-18-2008, 04:51 PM
Repalacing a blown fuse or resetting a breaker is a heck of a lot easyer than rewiring a fuse link!
  #17 (permalink)
Old 05-18-2008, 11:56 PM
malc's Avatar
Living At The Speed Of Life
Read Installation and function and NOTES about Fusible Links
here at MAD.
  #18 (permalink)
Old 05-19-2008, 12:37 AM
malc's Avatar
I would install 2 40 amp fuses. 1 between each relay and the fan.
Fuses are installed between relay and power source, ie the battery.
  #19 (permalink)
Old 05-19-2008, 09:27 AM
Boostedpimp's Avatar
poor
alright so basically this is what I should have correct?
  #20 (permalink)
Old 05-19-2008, 04:14 PM
malc's Avatar
Run one wire from each of the relay 30 terminal to 12 Batt source both fused.
No need to fuse your wires to the 86 terminal.
EZ wiring project zipfactor Electrical 3 05-21-2006 04:55 PM
Where to Put All The Relays Viet Nam Vette Electrical 11 02-18-2005 12:49 PM
Wiring An Electric Fan Using TWO Relays horvath Electrical 29 05-13-2004 12:57 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 06:18 AM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 12:03 PM
