Wiring a vacuum pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 04:57 PM
I need some info on wiring a vacuum pump for power brakes. I know there are two wires. Red for power and black for ground. What can I wire those to so it works only when key is turned on? Also how do I wire a switch to it so that it kicks off once the correct vacuum is reached?? thanks
Old 07-22-2012, 05:47 PM
EOD Guy's Avatar
If low vacumn is an issue at low RPMs...... you might think of installing a "Hydro Boost" system. It works off the power steering pump...... I installed one in my 67 Camaro and I like it.....
Old 07-22-2012, 06:05 PM
Yeah I looked at those and don't like the price but was looking on ebay and can get a Volkswagon/Audi pump for around 50-60 bucks. I don't know what else I would have to end up buying buy The hydro is too much money for me right now. A canister wouldnt work either.
Old 07-22-2012, 07:41 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
First of all, you'd want to find a switched power source that is only on when the ignition switch is in the run position.
DO NOT use the power feed for the coil, though.
I would think that you could use a vacuum switch like his one
Cole-Hersee # 9253 to cycle your pump.
9253 Vacuum switch 6-12 in Hg
spst, insulated.
contacts open at rising vacuum, contacts close at falling vacuum.
Mounting stem: 1/8" -27 dryseal thread.
Operating range: 6-12 inches of mercury (20.3-40.6kPa).
Replaces AMC 3156149, Chrysler 1770093, CH-2569, Ford C2TA-11516-A. SPST, Insulated, Normally Off
I'd wire it with a fuse as close to the power source as possible and connect it to the red wire on the motor. I'd use this switch on the ground side and connect it to the black wire on your motor. The switch would complete the circuit (make the motor run) somewhere in the 6-12 in/hg range.
I was just thinking that you could also wire in a circuit for an indicator light so that you knew when / how often it runs.
Old 07-22-2012, 08:49 PM
EOD Guy's Avatar
Using the switch above, I'd wire it with a relay....... that way the relay takes the load of the pump vs the vacumn switch.
Name:	vacumn switch.jpg
Old 07-23-2012, 05:19 AM
You may want to take a look at the info in this article, and follow the links to see what else you can find. Its an article about putting a vacuum pump in a GMC motor home to get better brakes (not your exact application), but does have info about GM cars where you might get a complete assembly that includes the vacuum pump and switch.
GMC Motor Home Pages
Bruce
Old 07-23-2012, 12:08 PM
Thank you guys for the help. I am gonna have to figure out how to wire this in. I dont know much about wiring but was told not to wire into the coil.. Does anybody know what to do for the wiring. 2 wires
Old 07-23-2012, 12:45 PM
This Pump would work. Dont know if it has a built switch...says 1..2..3.. on the plug in on the inside.....Factory OEM Hydraulic Power Brake Booster Vacuum Power Brake Pump 20998928 | eBay
Old 07-23-2012, 05:07 PM
EOD Guy's Avatar
for two wires....I'd follow the advice in post #5
Old 07-23-2012, 05:10 PM
I believe I will use a relay like shown but use a toggle switch and just turn it on when I need it.. Do you have to splice the wires for the switch/power?
Old 07-23-2012, 08:10 PM
EOD Guy's Avatar
Just wire the toggle between the vac switch and the ground
Old 07-23-2012, 09:20 PM
I am gonna run just the toggle switch with no vacuum swotch and flip it on when I need it
Old 07-23-2012, 11:14 PM
66GMC's Avatar
Seriously?
We're talking about power brakes here.
Yes, the booster has a check valve that (if working properly) will give you a couple of assisted applies, and yes, you can still aply those brakes manually with both feet on the pedal.
That Cole-Hersee vacuum switch #9253
retails for about $18.00 CDN
This bosch relay with mounting bracket
BOS 0-332-019-150 is $7.89
The connector pigtail (optional)
Grote 84-1041 is $13.83
ATO fuse-holder with bracket and protective cap (optional)
Grote 82-2166 is $3.15
Amber Indicator light (optional)
Echlin SW160 $9.09
(All prices are Canadian retail ... much less I am sure in the USA)
Besides all of the above ... forgetting to turn that toggle switch off and running the vacuum pump motor continuously is NOT going to be good for it, or your pocketbook.
I urge you to reconsider and just do it the right way ... for the sake of what ... $50.00?
But hey ... it's your ride.
Old 07-24-2012, 07:24 AM
Gotcha yeahh I plan on running it the right way but do I put a fuse on the switch
Old 07-24-2012, 01:39 PM
66GMC's Avatar
I would install a fuse (or choose an already fused) on the "hot" side ... as close as possible to the power source. You'll want to choose a fuse amperage a bit higher than what the electric pump motor requires, as most electric motors draw more at start-up than they do running.
Check EOD Guys diagram in post #5
AC Vacuum Pump? Coodeville Garage - Tools 0 08-17-2010 05:54 PM
Vacuum pump deno Hotrodding Basics 3 11-26-2008 05:48 PM
Vacuum Pump MI2600 Garage - Tools 17 08-06-2008 01:50 PM
Lt 1 Vacuum Pump big block camaro Engine 0 02-27-2007 12:15 AM
Bad Fuel Pump...Pump or wiring? Huckster Electrical 10 04-26-2005 09:23 PM
