Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-10-2004, 10:28 PM
bowtieorbust bowtieorbust is offline
Witch head gasket to use.
I've got a 355sbc with a set of World Product S/R torquer head's that have the 76cc chamber's, a set of Sterling Speed Pro hyper, piston's with a .125 dome on them, that are .020 in the hole and with a .041 head gasket, it's supost to make around 9.3 c/r. Now this will give me about .060 quench. Now would anyone know about how thin of a gasket i can use to make the quench better without push'in the engine much over 9.5 c/r because with iron head's i want to keep it pump friendly.
Old 03-10-2004, 10:39 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: Witch head gasket to use.
a steel embossed gasket should work, most are between .023 and .031. check the Fel-Pro or Victor-Reinze listings.
Old 03-10-2004, 11:07 PM
79transam's Avatar
79transam 79transam is offline
Life's 2 short 2 keep it stock
I went with NAPA's beaded steel head gaskets. They're about $12 a piece and compress to .015 I think. They must be retorqued though.
Old 03-10-2004, 11:22 PM
What would be an ideal quench for a 355sbc on pump gas, i've allway's thought .040 was kind'a tight, althow be'in .020 in the hole and a .015 gasket would make it a .035 quench. (Please help me out here)
Old 03-11-2004, 12:33 AM
ChevyIIMan ChevyIIMan is offline
I have used GM .28 Composite Gaskets on the last 2 builds.
Great sealing gaskets and still a composite instead of a shim.
Old 03-11-2004, 07:05 AM
firechicken383 firechicken383 is offline
Or you could use the Mr. Gasket steel shim gasket. .018-.020 thick. That would put you at .038-.040.
Old 03-11-2004, 07:58 AM
machine shop tom's Avatar
machine shop tom machine shop tom is offline
ASE-Certified Master Machinist
When using steel shim gaskets make sure the block and heads are STRAIGHT. I have had a few problems with sealing steel shim gaskets on engines with head and deck surfaces that weren't resurfaced. BTW, steel shim head gaskets don't need re-torquing. Any where from .040"-.045" piston-to-head should be fine.
Ya cain't fix stoopid, but ya kin TAX it!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
