-   -   Wix oil filters (http://www.hotrodders.com/forum/wix-oil-filters-207603.html)
goldenbullet44 10-24-2011 07:30 PM
Wix oil filters
simple question
Would it hurt my engine if i ran the wix 51060Racing filter????? i do drive it on the street aswell as racing it..
S10 Racer 10-24-2011 07:47 PM
Originally Posted by goldenbullet44
simple question
Read the box this filter comes in and then you be the judge, it's your motor.
* "Not intended for street use."
* "Warning: Wix racing filters are designed for racing purposes only, and if used on street-driven vehicles, pre-mature engine wear is possible."
* "New vehicle and equipment warranties are void when this product is used in competitive racing or on modified high-performance engines."
goldenbullet44 10-24-2011 07:48 PM
Gotcha.. im good gonna stick with the regular filter.
ericnova72 10-24-2011 10:16 PM
If you intend to do frequent oil changes(2000 miles or less) so as to keep built-up wear particles in the oil to a minimum, there is no problem using a race filter. They just aren't intended to use for 10,000 miles change intervals.
The race filter doesn't filter as fine a particles out, as a race engine theory is full volume of slightly dirty oil is better than too little oil because of a restrictive filter.
