Wix Racing Oil Filters??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2006, 05:46 PM
camaroman7d's Avatar
Are any of you running Wix "racing" oil filters? I am at a stage in my project where I am mounting my remote oil filter set-up. It is a "racing" set-up (huge filter). I bought a case of filters (Wix Racing) probably 6 months ago I never bothered to open the case until today. I noticed on the box of the filter it says "Caution: not intended for street use." It is a very heavy duty filter it goes on to say how strong they are (500psi burst rating, anti drain back, and all the great ebenefits of using it (including more HP, however that works). There is another warning that says "Wix racing filters are designed for racing purposes only and if used on street-driven vehicles, pre-mature wear is possible." The part number my kit calls for is 57004R or equivalent (I bought the 57004R). At $15 each I plan to use the 6 I have but, maybe I need to look for something different for future use?
My question is why would this filter not be "recommended" for street use? Does it not filter as well as other "street" filters?
Thanks,
Royce
Old 03-20-2006, 05:52 PM
coldknock's Avatar
Yep, just like K&N filters. Passing oil at a high rate means more crud makes it through. If you change your oil fairly often it won't be a concern.
Larry
Old 03-20-2006, 06:16 PM
LilSmoke's Avatar
Hey Royce, Im using a 51515R on the dragster and havent noticed any abnormal stuff getting thru.IE:dont see anything gong thru the bearings.Changing about every 4 races depending on how many passes. This is on alcohol.Was told by the local dealer that it just has a higher burst pressure is all.
Old 03-20-2006, 08:24 PM
I had the same question so I called Wix and the tech person stated that the media is different then the street version and it will allow more dirt and particles to make it through the filter in return for the higher flow.
Tmod
Old 03-20-2006, 08:28 PM
Thanks for the input. I always change my oil regularly but, I will drive the car on the street. I proabaly change my oil every 1000 miles, only because of the time factor. I don't drive it daily and it will see a ot of short trips to burger runs, cruises, etc.. It will also see 2 -3 trips a year of 300-500 miles, that's about it. So You figure maybe 2 oil changes a year, sometimes more.
I'm going to give the Wix filters a try. I think they are more free flowing and that's why they don't "recommend" them for the street, there are a lot of guys that don't change their oil regularly.
Edit: Thanks Tmod, you posted while I was responding. Good info I should have thought to call them.
Royce
Oil filters belairgauld Engine 2 02-19-2006 09:45 PM
Honeywell Oil Filters poncho62 Engine 3 03-18-2004 07:50 AM
Speaking of Fram oil Filters Rad Ray Engine 3 12-02-2003 09:12 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 06:17 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 08:20 AM
