wolo ooga horn major problem!!!
i just recently bought the Wolo Ooga Horns... i installed them the way that it said to in they're instructions. when i connected the battery it just honked... i have it wired to a push button in my cab of my 2003 ford ranger... i disconnected that and actually did a complete circut with two hots running to the switch and i grounded it right onto the negitive terminal... IT WORKED! but after the truck ran for a min the wires got flaming red hot, and nearly started a fire... im getting ready to just junk this stuff... unless i can get some help... please help me with diagrams or anythingthing else you can think of that would help me understand this more... oh ya forgot to mention... i did use an inline fuse on the hot wire... thanks alot...
IT said use 16 or higher(thicker) so i used 16... should i step it up to like a 14, 12, or 10?
should i use a relay? or just by pass it...?
Just wire it straight to the battery. Battery + to fuse to horn and then back to the battery for the ground. My old 72 was wired that way except it didnt even have a fuse in it. Im not the one that wired it up that way and i never thought enough about it to put a fuse in line. Im not sure i ever used the horn on it tho anyways. It also had a button switch on it for the horn button, as the stock steering wheel was replaced with some piece of crap TINY BG wheel.
if you wire in relay in properly your switch will last a lot longer, because then the switch is only passing about 2 amps through it and the relay is switching the higher load.
i used a thicker wire this time and it worked perfect but after about 10-15 mins after my truck was running it quit working?!?!?!? what do i do now...?
I will guess you burnt out the switch, check for power and ground at different places to test it.
Vince |
Vince |
ahoogah horns take a lot of amps.. read the package and you will realise they can draw 20+ amps.. and relays are reccomended to correct this. I recently wired an original 6v Ahoogah horn into my '51 Chevy, but I disconnected the original horns and used the relay.. after adjusting the 50 yo horn, it sounded just like it should
| Replace existing horn w/ ooga horn? | BobbyG-39 | Electrical | 14 | 11-03-2007 01:58 PM |
| broken ooga horn? | sierragrande | Electrical | 2 | 04-17-2007 04:27 PM |
| broken ooga horn? | sierragrande | Electrical | 0 | 04-17-2007 09:54 AM |
| Ooga Horn | Pats | Introduce Yourself | 2 | 04-09-2007 07:30 PM |
| Broken ooga horn. HEEEEEEEELP!!!!! | Pats | Off-Topic | 0 | 04-09-2007 07:20 PM |
