Wont go into park? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 02:24 PM
Last journal entry: Motor build up 2
Wont go into park?
Hey guys i got a new netural saftey switch for a 66 mustang ive been working on. Installed it and have had some issues that hopefully are easy fixes. One the middle bolt came out and it wasn't a bolt at all? Not to sure but wont tighten up like it seemed to be when i started. And know after all that the car wont go back into park? Any help would be great. It has a stright six and i would say the tranny would be a c4, its an automatic. Thanks guys
Old 09-08-2009, 04:41 PM
T-bucket23's Avatar
Wiki Edits: 26
If this is the type at the bottom of the column you may not have it positioned properly
Chet
Old 09-08-2009, 06:14 PM
floor shift. My father in law beleves a pin or something feel into the transmission when we pulled out the center shaft thing and is blocking the park selector.
Old 09-08-2009, 06:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
define : center shaft thing
Would this be the input shaft?
Old 09-08-2009, 08:50 PM
the center bolt that goes through the neutral safty switch. It dosn't seem like a bolt to me, no threaded ends
Old 09-08-2009, 09:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like the rod for the TV linkage is what you pulled out. that should not pull out much since there is a linkage piece on the inside end. that end moves a valve inside the valve body
they are known to break off and fall , not common , but it happens
Old 09-09-2009, 04:59 AM
ok is it an easy fix or does it have to be taken to a shop to be repaired?
4t60E trans stuck in park even when in other ranges fast68 Transmission - Rearend 5 07-16-2009 12:23 PM
Need to rig up a park brake in the cab... murrsue Suspension - Brakes - Steering 5 09-03-2006 08:19 PM
Taurus Hangs Up in Park Position... awbazar Suspension - Brakes - Steering 2 06-19-2006 10:51 AM
E-Town Raceway Park needs your help. coldknock Hotrodders' Lounge 17 07-30-2004 06:15 AM
Double Pole Park Lights horvath Electrical 5 08-14-2003 09:05 PM
