Won't Go Out of Park - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 05:31 PM
Hey,
I hope I'm posting this in teh correct area? This morning my 1977 Scottsdale 350 wouldn't shift out of park. I tried shifting it in reverse, 1st, 2nd...ect. Nada. So I checked the tranmission fluid... and it was GONE. There wasn't a streak of it on the stick. I'm not very vehicle savvy so would you guys be able to name off a few things that could be wrong? About 7-8 days ago I put a little too much transmission fluid in but I highly doubt that's the issue. I did get her stuck in some water last Friday... could it be the seal?
Input, links...anything would be appreciated.
And if I've posted this in the wrong area, please re-direct me.
Thanks,
J
Old 05-23-2005, 06:37 PM
Jmark's Avatar
Well, first off you need to fill it back up and look for leaks. Put 2 quarts in it and then start it. Check it idling in park. Fill it to the "full hot" mark on the stick and see if it will move, then look for leaks.
If its too low, it won't go into any gear, but if you keep trying, it will burn up the frictions and pump.
Old 05-23-2005, 06:40 PM
poncho62's Avatar
Wiki Edits: 5
Betcha............one of your tranny cooling lines is rusted out.
Old 05-23-2005, 08:36 PM
Follow Up
I did put some transmission fluid in it and found out the leak is in the seal.... looks like the motor's going to have to be pulled...
That's aight... I like to play .
Anybody think me putting too much transmission fluid had anything to do with it?...
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 12:49 PM
E-Town Raceway Park needs your help. coldknock Hotrodders' Lounge 17 07-30-2004 07:15 AM
Stumble off idle in park, carb or ignition problem Dubz Engine 3 05-18-2004 11:29 PM
Double Pole Park Lights horvath Electrical 5 08-14-2003 10:05 PM
1991 Buick Park Avenue Bent Wrench Hotrodders' Lounge 40 11-04-2002 10:28 PM
