wont go in reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2006, 02:25 PM
wont go in reverse
My son just bought a 1995 ford explorer xlt. He got it stuck in mudd and know it wo't go in reverse. What do you think?
Old 02-25-2006, 02:34 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If he didn't rake the undercarriage on anything solid and bend linkage it may just have some mud or gravel jammed in it. Is it an auto or manual? Will the shifter not move to reverse or does it just not move when put in reverse?
Old 02-25-2006, 02:43 PM
wont go in reverse
It is an auto. How would you clean it! yes the shifter moves to the reverse position it just wont engage.
Old 02-25-2006, 05:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You need Crosley
Things I mentioned were seat of the pants easy to check ideas.
Hopefully, Crosley will spot your post, he's definitely the trans guru and the go to guy.
Old 02-25-2006, 05:23 PM
Wiki Edits: 31
brother had a '90 Ranger that he took off roading, after that it would not go in reverse afterwards, shifted the gears fine, but just revved up in reverse, it's 4wd right? the A4LD 4x4 trans isn't very good, smell the fluid and go from there, might need a new trans, or a rebuild.
Old 02-25-2006, 08:30 PM
Frmly sc*ot.
A4ld?
A4LD?
I have an '87 Aerostar with that POS!
The sprag [OD?] and hub was chewed up resulting in no reverse sometimes and no drive in the OD position.
I hAd to replace the sprag, hub [including planetary gearset, and outer hub] which cost me about $250 from a *discount* trans store in my area.
I have the rebuild manual and supplement.
The first sentence in the manual says, "Since it's introduction in 1985, almost every part of the transmission has been redesigned. "
I BELIEVE IT!
Old 02-25-2006, 08:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what is the history on the trans?
4.0 v-6 engine?
original trans?
A rebuild at some point?
Mileage?
common reverse failure on the tranny is rubber seal gets hard and no longer holds pressure.
Old 02-27-2006, 09:08 PM
should of got him a jeep i would say cj-5 lol im just playing
Old 03-03-2006, 10:52 AM
cruiser22's Avatar
Shadetree wannabe
I had the same problem in a car of mine once.. when i shifted in reverse it would actually go forward.. come to find out i had bent a pin that holds the shifter linkage to the tranny... did it when trying to burn out by throwing it in drive(stupid).
Anthony
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 05:07 AM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
350tranny. no reverse. Sonkey Transmission - Rearend 3 02-11-2004 11:31 PM
