wont idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2012, 08:05 AM
wont idle
383 runs rough and pops a little out of exhaust and wont stay idling. edelbrock 600 cfm manual choke. msd hei ign. eddie heads and intake. new altenator. in an 84 gmc shortbed. checked timing and is 8 initial and 28 total. more than that it pings. any suggestions. a short maybe? New altenator problem?? Help. Thanks
Old 01-04-2012, 09:27 AM
gerbsinmd's Avatar
sounds like a vacuum leak. My car did the same thing, mine was leaking between the carb and intake, had the wrong gasket .
Old 01-04-2012, 09:56 AM
Last wiki edit: Stroker 351 W Ford Motor=Building
test=?
Try a compression test - betetr yet a real leakdown test with carb open- se if ther may be a exhaust valve not seating correctly-Thats my guess? should show low or no compression on 1 at least?/
350 sbc wont idle 72ardosnova Engine 3 12-15-2011 11:34 PM
Holley 670 wont idle Hugger355 Engine 5 04-25-2011 07:37 AM
engine wont idle pwiehejr Engine 8 04-07-2011 09:11 PM
3800 wont idle? runn141 Engine 6 11-02-2008 05:53 PM
Q-Jet wont idle?!? 87442lover Engine 5 01-25-2004 12:01 PM
