wont idle after warm. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 09:05 PM
got a 350 vortec heads edelbrock qjet and the old school 350 hp 327 cam. 3 weeks ago engine running great. It has sat for those 3 weeks. went to let run. bump the starter and she fires right up. she idle fine for about 5 minuets are so. the wont idle for ****. let set for a while and she fires right off and idles a while again. Any ideas.
Old 07-24-2012, 10:39 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Check the fuel filter.
Check that fuel tank is vented and working properly.
Do a fuel pressure test.
Old 07-25-2012, 12:10 PM
check spark with inline tester, as you probably know heat creates resistance. unless its a brand new coil never eliminate from equation. just a thought.
Old 07-25-2012, 08:44 PM
OK changed both filters. no difference. the throttle response is good will hold hight rpm. I did use some starter fluid and it would keep running. I sprayed at the base of carb to check for air leeks nothing there. If i hold the choke half way down it will idle well. can idel screws come out of wack in a few weeks just setting aorund?
Old 07-27-2012, 07:29 PM
Ok up date. I pulled the carb replaced the gaskets. tightened everything down. same ****. When i drive it other than idle it does fine. slow way down stomp the pedal no hesitation. hold MPH no problem
Old 07-28-2012, 09:00 AM
I had the same problem with a qjet. It had backfired and burned the top of the cork style float and stuck it to the top of the carb. It would run for a little and quit. It would sit and leak the bowl back full start and run a little. Take the top off the carb and make sure the float is moving and set correctly. This was on a 70 Judge. Mike
Old 07-28-2012, 11:08 PM
its an edelbrock q jet so has updated float. If i leave the hot wire of the choke she will idle fine. Once u let the chock open she goes down hill. spraying around the carb makes no difference. this just make no since. the truck ran great 3 weeks ago. then bam **** idle.
Old 07-29-2012, 07:38 AM
predator carb guru's Avatar
Mark Goulette
Your idle is lean, needs to be richened up. Adjust the mixture screws OUT (counter clockwise) to add more fuel. It runs with the choke on because the choke restricts the airflow and forces more fuel into the motor when it's cold........
Some basic tuning is all you need.
Old 07-29-2012, 07:39 AM
Mark Goulette
I missed that part. Check your idle air bleeds for blockage. They are the little holes on the top of the carb near each of the primary venturi. Blast them out with carb clean and see if that helps.
Old 07-29-2012, 10:31 AM
I forgot to add that i had tried to adjust the screws. no help there.
wont idle task65 Engine 2 01-04-2012 08:56 AM
car wont turn over when it is warm chris 37 Hotrodding Basics 8 12-28-2011 02:28 PM
Quadrajet, high idle with warm engine kikkegek Engine 23 05-19-2011 05:45 AM
eninge wont idle 49fordp/u Engine 11 07-05-2010 07:34 PM
Strange idle problem – part warm engine 78transam Engine 2 10-26-2007 05:16 PM
