Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Won't idle under 60 degrees timing
Old 05-01-2011, 08:00 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Wiki Edits: 9
Originally Posted by AllRi5e
Thanks for the reply!
No, in its first incarnation it ran at 13 degrees initial. Since then I've installed new heads, the 770 carb and put the battery in the trunk. Next time I'll change ONE thing, check it and move on to next thing.
I added a timing tape the other day so I could use a cheapo timing light instead of my digital. Same reading with both lights.
If I stabbed the dizzy incorrectly, couldn't I just rotate the cap until I found normal timing on the balancer?
Well, the cap won't rotate without the distributor, moving the timing. Just moving the wires one tower should would do it.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
