Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Won't idle under 60 degrees timing
Old 05-01-2011, 09:03 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Originally Posted by dgcantrellsr
I think the heads are too big & the carb is too big. JMO That's what was changed.
Those aren't the problem and aren't going to change the timing. Too big or not, the rotor is in the wrong position.
Semper Fi
