Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Won't idle under 60 degrees timing
Old 05-01-2011, 09:31 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Originally Posted by bubbahotep
That carb seems ok to me assuming its the vac secondary it'll size itself accordingly
Your sure that timing light is any good with the MSD? Used it before on any msd systems? Some lights cant read multispark correctly
At 20' (for example) timing what exactly happens? Does it just stall out, sputter, or rpm drops?
The rough idle and fouled plugs you describe sounds like a carb or spark issues. At 60' timing what are your rpms at idle? It sounds a little like your using the timing to compensate for bad fuel mixture or even a dead spark on a cylinder.
I recall some lights aren't compatible, and require use of an Equus type digital light. Yours might be that, but like he says here...check to be sure.
Semper Fi
