-   -   Won't Shift (http://www.hotrodders.com/forum/wont-shift-95801.html)
Zeater1 08-14-2006 07:21 PM
Won't Shift
I just installed a new motor and transmission into my 1968 El Camino everything is brand new. I have 2 question.
1. It won't shift during hard excelleration, it's fine in normal driving mode.
2. It seems to slip in low gear, could I have overfilled the transmission with fluid?
Any help would be great.
53_belair 08-14-2006 08:14 PM
1. What trans are you running?
2. Does it shift if you let of of the gas after a hard accel?
Zeater1 08-14-2006 08:20 PM
Won't shift
The trans is a 350 and yes it shifts ok if I let up on the gas. I have tried using both the Large and small Vac tubes in the front of a new Edelbrock carb?
IanRiordan 08-16-2006 05:27 AM
Check the kickdown cable adjustment, generally if it is a modulator problem they won't upshift.
