Won't Shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2006, 08:21 PM
New Member
Won't Shift
I just installed a new motor and transmission into my 1968 El Camino everything is brand new. I have 2 question.
1. It won't shift during hard excelleration, it's fine in normal driving mode.
2. It seems to slip in low gear, could I have overfilled the transmission with fluid?
Any help would be great.
Old 08-14-2006, 09:14 PM
1. What trans are you running?
2. Does it shift if you let of of the gas after a hard accel?
Old 08-14-2006, 09:20 PM
New Member
Won't shift
The trans is a 350 and yes it shifts ok if I let up on the gas. I have tried using both the Large and small Vac tubes in the front of a new Edelbrock carb?
Old 08-16-2006, 06:27 AM
Check the kickdown cable adjustment, generally if it is a modulator problem they won't upshift.
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 10:20 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 10:08 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 12:59 PM
