Hotrodders Bulletin Board
#1
Won't shift into third while accelerating
Oh boy.........me thinks I hear a very bad sound coming from my transmission. Something sounded like it let go, and now it will not shift into third while accelerating...but will shift when I start to lift off the pedal....thats when you hear the rattling, but only in third. If I shift down it stops......This is a six month old B&M 350.I do not abuse this car. It is a weekend cruiser. I romp on it a little . Could this be only the torque converter ? How can I tell ? This is my first automatic and I am not sure how to proceed..........jerry
#2
re: Won't shift into third while accelerating
I don't know about the noise but make sure your vacuum line from the tranny is hooked to the manifold Had this same problem on my vette after working on my carb. must have accidently knocked it loose.
#3
If third gear is acting up.... how is reverse ?
======== If you can't fix it with a hammer, you have an electrical problem. |
Back to top |
Similar Threads for: "Won't shift into third while accelerating"
| Trans seems to shift into neutral during the 3-4 (overdrive) shift | Rocketmann66 | Transmission - Rearend | 2 | 06-12-2005 09:21 AM |
| 4L80E diesel computer | 5foot2 | Transmission - Rearend | 2 | 04-09-2005 11:48 AM |
| 700r4 won't shift at WOT | Alex99 | Transmission - Rearend | 39 | 02-15-2005 08:08 PM |
| Stall wrong, transmission shift adjustment, suggestions? | jsdailey | Transmission - Rearend | 3 | 10-26-2004 10:59 AM |
| Tranny shift problems. | chevcamz28newbie | Transmission - Rearend | 6 | 08-09-2003 04:52 PM |
