Won't shift at WOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2002, 02:07 PM
The Vandal's Avatar
Engine Tech Addict
Post Won't shift at WOT
My TH350 (behind a 350) will not shift at WOT. I have to lift to get it into 2nd. If I don't lift it just keeps buzzing away. What can I do? Thanks guys, this forum is really helpful.
The Vandal
Old 01-03-2002, 05:33 AM
Post
Sounds like a vacuum problem, check your connections at the manifold and the diaphram, possibly a bad diaphram or not mounted correctly.
Old 01-04-2002, 01:21 PM
Post
vacuum is a thing to check but also your detent cable and vacuum assembly underneath the tranny.
Old 01-05-2002, 05:51 AM
Post
I meant to say modulator not diaphram, sorry.
