wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2008, 06:47 PM
Thumper_Pumper's Avatar
muddin maniac
Last journal entry: moter
wont start
all right iv got a 64 chevy that im sure will start but the wireing is bad.
when i put the batter in it the light under the hood comes on but no start or even click so i need some info on were too check to see were there could be a problem.
im goin to restor it but i just want too get it goin first before i replace evrything.
thanks
Old 05-12-2008, 07:08 PM
poncho62's Avatar
Wiki Edits: 5
You probably don't have the secondary power wire hooked up or its broken. There is the large wire that goes from the positive of the battery to the starter, and there is also a smaller wire that goes to the rest of the accessories.
Also, check the big ground wire that goes from the negative to the engine block. Also. make sure the engine block is well grounded to the chassis......
That should give you a start.
Old 05-13-2008, 02:20 PM
muddin maniac
well i think its beyond the starter cause i can touch the 2 starter wires to the pos batt cable and it will click and try too start but it wont turn over all the way but i know it has enough juice but i dont think its getting a good connection
Old 05-13-2008, 03:54 PM
poncho62's Avatar
Wiki Edits: 5
OK...lets try again...
1st....check and make sure your grounds are good....and tight
2nd.....You need the big wire to go from the + on the battery to the big post on the solenoid of the starter.
3rd....You need another wire from the + of the battery, to the ignition switch. Do you have power at the ignition switch?
4th......When cranking the engine, you need 12 volts from the ignition switch to the small post (closest to the engine block) on the solenoid.
If you have all that, it should turn over.
5th....You need power to the coil to make the spark......Distributer needs to be working, set right at the right timing and all that jazz.....
For now, worry about steps 1-4
Old 05-13-2008, 05:54 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Are you sure the battery has enuf power?
Just because it lights up one bulb a good battery it makes not.
Rule of Batteries is one CCA
Cold
Cranking
Amp
per cubic inch of motor @ 70* F
2CCA @ 32*F
Minimum
R
"SlowRide66"
"Illegitimis non carborundum"
Old 05-13-2008, 07:45 PM
muddin maniac
all that is good but i dont think that iv got power to the ignition switch and i dont want to spend the time checking evry wire so i just wanted to start it so were do i touch the pos batt cable to the starter celinoid to get it too crank? heres a pic of the celinoid...
ID:	29906   Click image for larger version
Old 05-13-2008, 07:52 PM
Wiki Edits: 31
touch the 2 terminals togther with a screw driver, it should crank over. run a jumper wire from the battery to the + side of the coil ( removable so you can shut it down by removing from the battery ).. squirt some starter fluid in the carb, crank it over and it just might start, but likely needs points and a condensor
Old 05-14-2008, 02:20 PM
muddin maniac
so i need the 2 terminals to be touching , witch are the two small bolts right..and i just run the pos batt cabel the the big bolt like it was and just touch the 2 terminals and it will crank?
Just conferming........Thanks
Old 05-14-2008, 02:34 PM
poncho62's Avatar
Wiki Edits: 5
No.......Connect the battery to the big terminal......Then, to make it crank over, take your screwdriver and touch the big terminal to the small one closest to the engine block.
Old 05-14-2008, 02:44 PM
muddin maniac
hmmm thats wat i thought and it just sparked and clicked but wouldnt crank and its not my batt cause i got the charger on it
Old 05-14-2008, 02:46 PM
muddin maniac
Quote(You need another wire from the + of the battery, to the ignition switch.)
theres only one cable from the pos batt that gose to the celinoid
Old 05-14-2008, 03:02 PM
poncho62's Avatar
Wiki Edits: 5
Then, your starter may be bad.......The ones in the picture look pretty ratty and old.......you could take it off, take it apart and clean it up.
Old 05-14-2008, 03:10 PM
Wiki Edits: 31
a battery charger won't provide enough amps to turn over an engine, if the battery has a weak cell, it will have low cranking amps anyway
Old 05-14-2008, 04:10 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Have you tried turning the engine over by hand? it may be seized.
Rich
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
crank no start meev182 Engine 7 06-17-2007 07:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 06:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 05:23 PM
caprice wont start? Brian Morency Engine 8 08-25-2004 12:37 AM
