won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2009, 05:20 PM
won't start
I just finished changing over my 54 ford 6cyl to 12 v neg ground. Everything works except that it won't start. It cranks about 50 to 75% faster than it did at 6v, and I expected that. Does the increased cranking speed affect the vacumm advance? The distributor was never removed and it ran as a 6v. It shows no inclination to start, not even with ether. It cranks as if the coil wire wasn't there. Everything that was supposed to be changed in the conversion, was. Thanks Joe
Old 09-13-2009, 06:39 PM
bobyell's Avatar
Did you check for a spark and correct timing?
And the cranking speed shouldn't be fast enough to affect timing.
Bob
Old 09-13-2009, 07:09 PM
302 Z28's Avatar
Are you still running the OEM distributor?
Vince
Old 09-28-2009, 02:26 AM
Corrosion across the points? Running a 12V coil?
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
crank no start meev182 Engine 7 06-17-2007 06:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
caprice wont start? Brian Morency Engine 8 08-24-2004 11:37 PM
