Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Won't Start
Thread: Won't Start
Old 11-28-2004, 12:17 AM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
How much fuel pressure?
Sounds to me like it's lean for some reason.
Open loop should have rich parameters for fast start up.
I'll assume you have tested the coolant temperature sensor.
This can cause a problem if it's reading high or faulty.
Another cause of a possible lean condition would be a vacuum leak of some type.
What type of ignition system does it have?
