-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   won't start after wireset and plugs (http://www.hotrodders.com/forum/wont-start-after-wireset-plugs-228623.html)
85impala 01-20-2013 01:37 PM
Hey guys,
I have an 85 Impala with the ccc qjet and 305.
I recently bought and installed a new summit brand wireset and new Ngk #6630 spark plugs.
when I first tried to start it, gas shot out of the carb and popped:mad:
So I triple checked the wires made sure their where they need to be, same thing :smash:
Finally I pulled #1 plug and turned the crank until the timing marks lined up on the compression stroke, the rotor is lined up with #1 on the cap. Re-stared it, Same result
It ran fine before the change
At this point I'm just confused, what could be wrong?
Any input is appreciated
Thanks
joe_padavano 01-20-2013 02:16 PM
Thanks
Uh did you run the wires clockwise vs. counterclockwise on the distributor cap? Chevy distributors turn clockwise.
85impala 01-20-2013 04:40 PM
Lol wow, I can't believe I did that I'm a moron. Thanks for pointing that out
:embarrass:
