won't start after wireset and plugs - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-20-2013, 01:37 PM
Hey guys,
I have an 85 Impala with the ccc qjet and 305.
I recently bought and installed a new summit brand wireset and new Ngk #6630 spark plugs.
when I first tried to start it, gas shot out of the carb and popped
So I triple checked the wires made sure their where they need to be, same thing
Finally I pulled #1 plug and turned the crank until the timing marks lined up on the compression stroke, the rotor is lined up with #1 on the cap. Re-stared it, Same result
It ran fine before the change
At this point I'm just confused, what could be wrong?
Any input is appreciated
Thanks
Old 01-20-2013, 02:16 PM
Thanks
Uh did you run the wires clockwise vs. counterclockwise on the distributor cap? Chevy distributors turn clockwise.
The Following User Says Thank You to joe_padavano For This Useful Post:
85impala (01-20-2013)
Old 01-20-2013, 04:40 PM
Lol wow, I can't believe I did that I'm a moron. Thanks for pointing that out
Recent Modern Electronic Engines posts with photos
Has spark & turns but won't start (won't even fire) loafing1 Engine 2 04-12-2011 07:50 PM
won't start: fuel? spark? timing? plugs? eatonde Engine 16 08-21-2008 03:41 PM
Starter won't start and fuel pump won't pump after engine reinstall Porschev Electrical 26 02-16-2007 04:43 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 08:20 PM
5.0 HO, Changed plugs/wires now starter won't turn over dmc12mk3 Engine 7 06-22-2004 02:12 PM
