wont start some times - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2002, 05:13 AM
cc69's Avatar
Post wont start some times
I notice when I drive my car for a little bit when I get back into it wont start. The only things that it does is the electric fans come on the accesoris work and the lights dim when I turn the key but the starter never engages. Then if I get under the car and jump the termanals on the starter with a screwdriver it starts, if the ignition is on. Any ideas where to start. Could I just have a bad conection at the terminals.
[ September 13, 2002: Message edited by: cc69 ]
[ September 13, 2002: Message edited by: cc69 ]</p>
Old 09-13-2002, 05:40 AM
Post
Could be a bad solenoid on the starter.
Old 09-13-2002, 06:07 AM
aka Duke of URL
Arrow
You need to perform a starting system draw test, i.e. start with the battery and trace voltage draw to each connection in the circuit. You may also have bad battery. You need to perform a deep draw test to see if it will hold a charge properly.
By stating that you can cross the starter solenoid and she fires, I would imagine a bad battery, cable or connection. Be sure to check all grounds. Battery to engine, engine to frame.
Old 09-13-2002, 10:38 AM
bullheimer's Avatar
NEVER use credit cards!
Post
FIRST OF ALL WHY ARE YOUR LIGHTS DIMMING WHEN YOU START THE CAR. TURN OFF YOUR LIGHTS! FIRST I THINK MAYBE YOUR SOLENOID IS STARTING TO GO. ARENT YOU READING THESE OTHER POSTS RELATED TO THIS PROBLEM WHERE I SAY THIS IS A COMMON CHEVY PROBLEM SO SHIELD IT WITH SOMETHING TO KEEP THE HEAT AWAY AND SEE IF IT HELPS. WHAT MAY BE THE REAL PROBLEM IS YOU ARE OVERLOADING YOUR IGNITION SWITCH. YOU SEEM TO HAVE ALOT OF CURRENT GOING THRU IT AND I'VE READ THAT THE SYMPTOMS OF A HOT STARTER SOLENOID CAN ACTUALLY BE CAUSED BY AN OVERHEATED IGNITION SWITCH AND THAT YOU SHOULD GET POWER FOR YOUR ACCESSORIES FROM EITHER 1- A RELAY-SIMILAR TO A STARTER RELAY, THAT ACTUATES YOUR ACCESSORIES, OR 2-A DIFFERENT SOURCE ALTOGETHER THAT DOES NOT INCLUDE THE IGNITION SWITCH IN THE CIRCUIT. TRY A HEAT SHIEL FIRST IT'S A QUICK FIX WITH A PIECE OF ASBESTOS WRAP OR THEY SELL METAL ONES THAT BOLT ON
Old 09-13-2002, 11:15 AM
cc69's Avatar
Post
When I say my lights dim I mean the intieror light if the door is open and the electric fans slow. I'll try these things and see what happends. I thought the heat might be locking up the starter but when I could jump it I was not sure because it turned over. Thanks for the advice.
