wood bed kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2005, 02:37 PM
New Member
wood bed kit
Just curious which wood bed kits you all prefere (ie. which company and type of wood). I need one for a black 70 chevy fleetside shortbed.
Old 08-13-2005, 09:19 PM
willys36@aol.com's Avatar
Wiki Edits: 21
All the ones from after-market companies are pretty much the same. I am sure they are made by the same company. Do you want a working truck or show truck? If the former, get the basic yellow pine kit. If the latter you can get the fancy oak kit but it will require a lot of maintenance to keep it pretty. If you have a table saw, you can easily make your won kit out of any wood you want to use. Here is the first page of several in my journal on how I made the bed wood for my '53 Chevy from Ipo (Brazilian iron wood) using nothing more than my table saw and drill press.
Help i need a Wood bed supermannscc Body - Exterior 1 08-02-2005 03:16 PM
wood bed thickness question 70chevyc10 Body - Exterior 4 04-24-2005 09:18 AM
spray/brush in bed liner on wood? akm Interior 2 05-09-2004 09:43 PM
Replacing wood bed in '53 Ford P/U first timer Hotrodding Basics 8 12-12-2003 05:08 AM
bed wood 78 chevy truck Body - Exterior 6 09-18-2003 09:46 PM
