Wood Dash - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-19-2013, 07:52 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Originally Posted by shine View Post
".............. there are too many quality finishes made for wood today to use automotive products.
My thoughts exactly, especially on the interior of the vehicle.
  #17 (permalink)
Old 10-19-2013, 07:55 AM
vinyldude's Avatar
Dan is right Spar varnish, spar has u.v. protection, and teak is the wood that does it best, all round.
  #18 (permalink)
Old 10-19-2013, 08:00 AM
hp246's Avatar
I'll have to check into Spar. this is actually an open roadster, so the dash will be subject to weather and UV. I've tried the Hardware store urethane, and polyurethane. It just peeled. I tried marine epoxy. I liked it other than it was very thick and didn't lay down flat. It left a lumpy finish. To date the only thing I've had success with is the 2K clear.
  #19 (permalink)
Old 10-19-2013, 08:40 AM
This has been a damn interesting thread so far, sure to learn a lot more reading the comments to come. I have never been a wood guy but always loved seeing a well done work no matter where it was. You guys are adding a new love of the wood interior pieces for me. It's got to be the right theme of the car to work, that is a given. But damn when it fits the car it is so beautiful to see it and I have seen some fine examples in this thread!
Thanks for the education!
  #20 (permalink)
Old 10-19-2013, 08:49 AM
vinyldude's Avatar
to get good results from varnish temperature should be about 80, applied in shade only, one full day of drying between sanding and coats, 5 coats minimum. i did some sailboat varnishing in marinas, have fun doing it.
  #21 (permalink)
Old 10-19-2013, 09:46 AM
good info. got a little wood in mine to finish.
Name:	interior pics 001.JPG
ID:	90593   Click image for larger version
Name:	interior pics 006.JPG
ID:	90601   Click image for larger version
Name:	interior pics 005.JPG
  #22 (permalink)
Old 10-19-2013, 10:26 AM
hp246's Avatar
Michigan, October. There is no such thing as 80
  #23 (permalink)
Old 10-19-2013, 11:57 AM
sedanbob's Avatar
Spar varnish is the traditional marine finish for exterior wood (usually Teak), found on boats - sun, water, salt spray. It stays somewhat soft, so it expands/contracts with temp changes. But as was mentioned, there are lots of modern wood finishes available these days. The Bedwood company makes all sorts of exotic bedwoods, and the finishes that go with them - good place to check what they recommend. Wood Finishes
  #24 (permalink)
Old 10-19-2013, 04:49 PM
delawarebill's Avatar
dash
i used bubinga from africa in my 46 . hardest wood i have ever worked with but was really beautiful wood . i burned up a couple of bits on it. does this look the same bill ??? wouldn't swear to the name or spelling .
over the years i have found automotive urethanes fail over wood . most wood will tend to gas out in sunlight causing bubbles.
i also routered out the back for switches.
no, yours is alot redder then mine was.. mostly like a red hue.
but yours is beautiful.. i had a custom furniture maker build mine. also gave a templet with a selection of sw's..
  #25 (permalink)
Old 10-19-2013, 04:55 PM
shine
i just saw the upper unit.. that's close.. here's a pic of my bucket dash..
  #26 (permalink)
Old 10-19-2013, 05:04 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
the other consoles were dark walnut . i apply dark walnut stain then sand. it darkens the grain . i have another console to do for my 54 ford truck soon but haven't decided on wood yet.
dash looks good. i had a t when i was younger. had the nut buster steering in it . scary damn car but a ton of fun .
  #27 (permalink)
Old 10-26-2013, 03:57 AM
BWS BWS is offline
Try some of this as a clear coat.
Thunderbird Archery Epoxy Bow Finish
faux wood dash paint barflymark Body - Exterior 15 05-04-2011 11:07 PM
New custom dash panel - glossy wood look cucumber1949 Interior 14 09-16-2006 08:25 PM
Making a wood dash-how thick? 5window Interior 2 03-11-2006 12:16 PM
Wood Dash Trim 75chevyman Interior 3 07-27-2004 01:27 AM
Wood dash kit for Camaro Yes or No? deathtoricers Interior 4 05-11-2003 10:32 PM
