wood , ploy, what to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 01:53 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
O'tay
I'm in the middle of reworking my gauge cluster on my 71 chevy pick me up.
and the autometer gauges. ole tyme style.. the lower 4) 2 1/16th"
fit the gauge trim like they are factory.. the top three , thats another story..
My Grant wheel is a walnut wood, and the center console that I'm grabing from the olds blazer the trim around the shifter match..
Soooooooooo, of course my idea to make the top three gauges(speedo/tach/clock) look like they belong there is wood to fill the gap between the gauge size and the trim gauge panel hole size.. and it'll flow well with the wood wheel and console trim..
the question is can I (do I ) use standard minwax poly.. or do I need a marine grade.. I have a little under 2 gallons of satin wood floor poly.. and gloss..
and do I poly all the way around the wood to basically seal it. to keep the swelling and shrinking down
thanks for any help..
Last edited by DanTwoLakes; 01-31-2012 at 07:34 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 01-31-2012, 07:33 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Moving to General Rodding Tech.
Dan
Old 01-31-2012, 08:58 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The polyurethane you have should work fine..put a seal coat on the back of the wood and for myself I prefer the satin finish on the wood but the gloss is fine as well..depends on your preference..
Sam
Old 02-01-2012, 08:02 AM
stich626's Avatar
gearheadslife
thanks,
matching the wheel will be fun
wood gone in p/u box price Hotrodding Basics 1 03-30-2011 10:07 AM
wood bed kit OperationMidnight Body - Exterior 1 08-13-2005 09:19 PM
Help i need a Wood bed supermannscc Body - Exterior 1 08-02-2005 03:16 PM
Wood eye? Madd Syntst Body - Exterior 7 12-24-2004 03:22 AM
Wood DOUG FEDOR Body - Exterior 1 08-08-2003 10:50 AM
