Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wood Replacement in 1936 Pontiac Doors
Old 04-26-2012, 10:50 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
I use square tubing...one way to get the curves is to bandsaw tthe tube to shape or you can invest in a bender from protools or jd2 and with the correct die bend tubing to the correct profile that you need. Actually you may use both methods in the construction of a new interior subframe.. good luck as you will be a skilled fabricator when done with this project..
Sam
