The wood in vintage auto - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-14-2007, 10:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Originally Posted by 31chevy
if I was to use square tubeing for the vertical posts where the door hindges bolt onto how would I fasten the hidges on same way as with the wood.
the three hindge bolts that would go through the sq tubeing i would think would need three horizontal cylindrical metal shafts to add stuctural support to the tubing right.
You will not likely to need the tubes in way of the bolts as that connection is not all that highly stressed..if it were your seat belt anchors or your motor mounts then putting tubes in way of the bolts is a good idea..
you can either bend your tubing or get some larger tube and set your bandsaw to the vertical and saw a curve into the tube leaving a u-shape that fits the curve of the body..either way is fine..
Sam
  #17 (permalink)
Old 08-14-2007, 04:57 PM
need strog32 chevy front doors
Last journal entry: Tbd
thank you all
  #18 (permalink)
Old 08-14-2007, 06:20 PM
Cape Cod Bob's Avatar
just got the latest issue of SR mag and they spent the article on choppin a chevy totally on the chop and nuthin on the tubin' .
There is a site i visited where a guy added the 1" 1" tube and had plenty of pix but I can't find that for u now.
If u make up a door post using 1x1 and doubled it up with space between with supports top bottom and in area of hinges ,then u could drill thru & thru bolt with out the sleeve.If only using one 1x , or one larger tube u will need a sleeve to keep from crushing the tube on tightning the hinge bolts, as u saaid.
Make sure u keep the door opening braced while doing bthis so u won't have to move anything later to get door to fit. Check fit of door .plenty of times while welding it up.
  #19 (permalink)
Old 08-14-2007, 06:54 PM
http://groups.yahoo.com/group/RobsProjects/
found his site for u. only thing is it's down till further ,however u can maybe leave an message?
  #20 (permalink)
Old 08-15-2007, 12:16 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
That was a good place to see a backyard build. Too bad he burned out and hasn't done anything that I know of lately.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  #21 (permalink)
Old 08-15-2007, 10:24 AM
ya thats rob the ammoman. Discovered his site a year or so ago . However half way through he put a password on his site. so i no longer could check his progress out .
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Trailer recommendations - wood deck cboy Garage - Tools 120 09-26-2007 11:33 AM
33 Chevy 5 Window Top Chop FREEFALL Body - Exterior 25 02-25-2005 07:59 PM
Vintage auto alarm system????? 421Bonneville Electrical 2 09-17-2004 05:53 PM
Vintage Auto Parts you must check it out roys63 Engine 0 10-01-2002 03:25 AM
