Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wood working
Thread: Wood working
Old 09-24-2002, 07:56 AM
badgesx2 badgesx2 is offline
I've got a 51 chevy pickup that i did the same thing to..i used luaun plywood (door skin) and it worked great..i wet it with water, not too much, and clamped it it a "workmate" and slowly bent it to the radius i needed and let it took a couple of times but it worked out perfect..the luaun plywood is cheap and has a good finished side for stain..i also used some 2x6's in the workmate and put the luaun between them so it would be closer to the point i needed the radius to start..i ran the luaun from door jam to door jam.. it fit in the groove at the back of the jam..there is a small brace there that you will have to notch out for..i also ran some 1x2"s across the cab braces to hold the luaun straight across the long span in the back of the cab..good luck..
