Yes, kerf cuts could work .... if the cab you're in is like your graphic, you've got a pair of faaaaairly tight curves to deal with. I'd suggest using as thin o' blade as you have, preferably one of those Japanese razor saws (or a sharp/thin hacksaw) and space the cuts close - 1/8" to 1/4". You can press it/mount it into place (after the soak), using the cab body as mold, then pour a line of wood glue along the top edge, and work it into the kerf ends with your finger, putty knife, or a compressed air stream. Before it dries, press a little kerf saw dust/glue into the kerf ends. Hit o' sand paper (120 grit folded to a stiff edge) and seal it.
