wooden sawhorses - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2010, 06:34 AM
wooden sawhorses
anybody have any good plans for solid wooden sawhorse ??? all the plans I come across would fold under the weight of a sheet of plywood , also what would be a good height ?? I am 6' 4" and have to bend down for everything .
Old 02-14-2010, 06:46 AM
sawhorse
I like to use a piece of I-joist for the main beam- 2x4 legs- takes about
5 minutes to put together and will hold a car body on a pair of them if
you make it long enough. Put a scrap plywood brace across the legs
under the beam to steady it. Jim
Old 02-14-2010, 08:48 AM
sqzbox's Avatar
My pipes are my music
better sawhorses
Good question for CUTHROATKID! "How to build a better sawhorse". (humor)
Old 02-17-2010, 12:04 AM
http://woodworking.about.com/od/shop...dSawhorses.htm
Use a couple of 10' 2x4's instead of 8's, and you could stretch the legs from 32" to 40".
Old 02-17-2010, 06:17 AM
Old Fool's Avatar
What are you setting on them?
Old 02-17-2010, 06:25 AM
sawhorses
I build them simular to those plans but use I joists for the beam and 1x4's
for the leg braces, plywood for the end braces. Saves some weight and
the I beams are very strong. Most real lumber yards stock i-beams or
you might find that a construction site has some cutoffs from stair cutouts
etc. Jim
Old 02-17-2010, 07:23 AM
Jim them are nice , about what I am looking for .
anything and everything , from drywall or lumber to be cut , to a temp work bench ( a bunch of 2x6's I have laminated together into a tabletop ) for working on cyl heads and as a scafold base , I had a set of the plastic ones but they don't like heat to well and you can't fix them when you accidently cut the top peice in two ( my step kid didn't know how to adjust a saw blade depth .......now he does ) as for the laminated I beam I might try that as I am near glulam and they sell shorts (scrap ends) to the public . My dad had a nice set with the tool tray in the legs he made when he was a carpenter , but my stepbrothers destroyed them .
Old 02-20-2010, 08:29 PM
Old Fool's Avatar
I would suggest making them height adjustable for all those varied purposes.
Process of doing a box floor with wooden planks? "70" Cougar Body - Exterior 5 07-09-2008 09:51 PM
dual-engine wooden Cadillac Jon Hotrodders' Lounge 2 04-15-2006 06:22 PM
wooden periodic table "table" Jon Off-Topic 2 03-19-2006 04:17 PM
Wooden box floor for Chevy truck OLDCHEVY General Rodding Tech 7 12-08-2005 05:56 PM
Wooden Templates for 28 chev nutter Interior 0 11-23-2005 12:21 PM
