Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Pad/Foam Pad/Products/whats ur Flavor
Old 12-03-2005, 08:48 PM
baddbob baddbob is offline
I voted foam and perfect it II, the wool pads are definately more aggressive but the 3M waffle foam pads work just fine for me so that's what I use. I then switch to a waffled grey pad for the polishing stage, and sometimes finish by hand when it needs to be perfect-don't laugh, yes a final rub by hand makes a difference.
Watch out for heavy swirl marks when using the wool pads and coarse compound, I've seen them so bad that they had to be sanded out with 2000.
Everyone has their own preference so use what works for you.
