I didn't see an option for wool for cutting then foam for final polishing. Wool pads will "git 'r' done", foam pads are sloooooow! I like to use a glaze with some abrasive in it on the final foam padding so if you run across an area where the sand marks are not all the way gone you can just linger there for a bit and make them go away!
