Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Pad/Foam Pad/Products/whats ur Flavor
Old 12-05-2005, 12:16 PM
chadsbodyshop49119 chadsbodyshop49119 is offline
Custom builder and painter
Last journal entry: Another test fit of the axle
Right now i'm using system one and like it alot.. used to use perfect it 3, but I like the system one better,, I use wool, then yellow foam then black foam... I don't like to do heavy cutting with foam.. it doesn't cut it for me, but I do like to do my finish work with foam...
How does system one compare to presta.. I definetely prefer the water based compounds after getting used to them.
