Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Pad/Foam Pad/Products/whats ur Flavor
Old 12-07-2005, 04:45 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by chadsbodyshop49119
Right now i'm using system one and like it alot.. used to use perfect it 3, but I like the system one better,, I use wool, then yellow foam then black foam... I don't like to do heavy cutting with foam.. it doesn't cut it for me, but I do like to do my finish work with foam...
How does system one compare to presta.. I definetely prefer the water based compounds after getting used to them.
That's really good to hear as I have a system One kit on the way Expensive kit it better work good!!!
Previously I have used 3M with wool.
