Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Vs. Foam Pad?
Old 06-26-2005, 09:10 PM
baddbob baddbob is offline
Wool pads are more aggressive than the foam pads and will leave some major swirl marks if not carefull, I've seen swirl marks so deep from heavy compound and a wool pad that the surface needed major resanding. The foam waffle pad works best IMO. Sanding to 2500 or 3000 only requires minimal buffing and makes for a better final product. If you need to remove a lot of material with a buffer you lose control IMO, better to wetsand to almost perfection then finish with some light buffing- this way I'm in more control of the final product. Years ago I would sand with 1000 then buff with a wool pad and 3M's heavy duty compound then step down on compound grit then finished with finesse- thought this was the best way to go, wrong. I've proven it to myself by doing panels side by side and comparing, sand to 2500 or 3000 then buff with a light compound and a foam pad. Try it yourself. Bob
