Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Vs. Foam Pad?
Old 06-26-2005, 09:15 PM
sevt_chevelle sevt_chevelle is offline
I agree with Bob 100%
Final sanding with 3000 grit actually speeds up the process and leaves behind a better finish.
For a newbie with a buffer a wool pad IMO is a bad idea. Much easier to lose control and burn throu. You can burn thou with a foam but its much much more forgiving...Eric
