Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wool Vs. Foam Pad?
Old 07-04-2005, 12:51 PM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by jcclark
I have always had a problem with scratches when I use a wool pad.
They usually can't be seen until I have the car in my garage under the
fluorescent lights. I've tried everything, cleaning it often, different
compounds, I always got a few scratches that I'd have to compound out.
I liked the wool pad because it's so much faster.
I have finally got a system where I don't use it at all.
I wetsand with 2000, usually by hand and block, then I use a DA, a
4ooo grit pad with water. It's a soft pad by Mirka. I think 3M has the
same thing. After using that the finish is so smooth that a foam buffing
pad with a medium polishing compound brings the shine out so
fast that it's actually faster than the wool pad. And I don't get any scratches.
That 4000 grit gives it a semi-gloss finish that barely needs buffing.
I am really interested in trying your process. What DA sanders works best with the Mirka pads? Do any come with the hook and loop backing needed for these pads?
And, how do you handle the contours and tighter curves on the body?
