Workbench - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2003, 02:56 PM
48aero's Avatar
Last journal entry: 53 Chevy PU
Workbench
I'm getting ready to redo my 48, but before I get started I'd like to finish out my garage as a nice shop. Does anybody know a web site that I could go to for some plans for a good work bench with drawers and doors under it. Thanks
Jesse
Old 10-09-2003, 03:37 PM
awsum34's Avatar
What are you going to use your work bench for? welding, assembling parts,
They have a work bench on www.diynet.com to get you started
Old 10-10-2003, 01:49 PM
Dragon J's Avatar
Last journal entry: Harley/Fire
Menards has 'kit' workbenches you assemble- just bought one for my new shop- they have sectional components you buy so you can make it as big or small as desired- drawers, etc. all in heavy steel. I think brand name was gorilla... very reasonable price- (cheaper than you could fabricate)
Old 10-12-2003, 08:05 AM
Kevin45's Avatar
Just one of the guys
Go to www.chevytalk.org and click on one set of the cars. Scroll down to the very bottom where there is a forum on Garages and ook thru the articles. One person did a whole thread on workbenches with detailed pictures. I went and got the addy. Here you go.
Workbenches
Kevin
Old 10-13-2003, 11:16 PM
Scuzzy's Avatar
Certified Cruck Lover
the Lowe's here in Amarillo carries those "gorilla" workbenches DragonJ is talking about, you may want to go check with them if you have one where you live.
Old 10-18-2003, 09:46 AM
Bluejackets67's Avatar
I'm building my own workbench. I plan on mounting the vises on a reese hitch type reciever. This way I can remove them and have a smooth top to through a piece of plywood on.
Old 10-19-2003, 04:45 PM
H2Os50's Avatar
New Member
Work Bench
You didn't mention what type of tools you have. If you have a table or radial arm saw with a dado I can send you pictures on how to build a very stout bench.
I used a solid core wooden door for the top with a 1/8" piece of hardboard set over the door.
If you have a Home Depot or Lowes in your area, try talking to the people in the lumber section. Sometimes they get doors in that are damaged on one side that they will sell for 50 to 60% off. You only need one good side for this project. A door without the holes for the door knob is best.
The nice thing about using the door for a top is that they are flat, smooth and strong.
I used 4 X 4's for the legs and 2 X 6's for the side rails. All of the pieces were cut down with the dado to form lap joints and assembled with glue and screws. The top rail was recessed just far enough to let the door and the hardboard set down and flush with the top rail.
Don't glue the hardboard to the door. When it gets torn up or too messy to use anymore, just lift it off and lay down a new piece. Hard board is cheap!
H2Os50
Old 01-08-2004, 07:44 PM
Gearhead forever's Avatar
I like to have my main bench completely made of steel. Its sturdy as hell, you can weld on it, it doesn't absorb anything and you can always put plywood or a cover down for a softer work surface. Metal filling cabinets under neath work pretty well, and you can also add wooden drawers underneath with drawer slides
My new garage is going to have all custom 18ga cabinets with slam latches and a welding bench with a completely closed base. (I'f I ever get around to building them) I like that clean organized look.
Old 01-08-2004, 08:27 PM
MI2600's Avatar
Member# 3287
One point I'd like to make. I found it was better to bolt the legs and side supports together. I found the nails didn't hold as well. But, my garage bench (2'X6') is just a simple top with a shelf underneath.
Old 01-09-2004, 05:33 AM
STUPID is as STUPID does...
You can also pick up damaged cabinets at any of the home centers. I bought a $430 dollar 5' long sink base cabinet for $80 bucks because it got dropped off the truck... I fixed it in 20 minutes, put it on casters, built drawers for the blank fronts and put an OSB top on it with some old Formica. It's a versatile roll around bench now and I use it for layout work, mixing paint, carb rebuilding, you name it... and it's got lots of storage underneath the sink area and 9 drawers...
Mark
Old 01-09-2004, 08:09 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Norm recently did a New Yankee Workshop 2-parter on building a workbench. You can buy his plans for $15.95 or a video/plan for $39.95 (twice the cost for twice the info of a standard NYWS plan) @ the New Yankee Workshop website.
http://www.newyankee.com/getproduct3.cgi?1201
Another version for $10.95/24.95,
http://www.newyankee.com/getproduct3.cgi?0106
Of course that is a wooden bench but could have a steel top for mechanical work. Wouldn't be suited for welding but a welding bench should be all steel and separate from a work bench anyway.
Old 01-12-2004, 04:32 PM
Another reason I like steel benches and cabinets, is it cuts down on the combustibles in the shop....In our area we have a volunteer fire dept. With response time to the station followed by the 12-15 min. drive to my house.... Plus, the garage and house are attached....
Old 08-08-2011, 12:46 AM
Workbench
Hello 48aero
I suggest Work Bench from *********.
The detail Specification is as follows:
Price $316.95
Free Shipping, Usually Ships in 24 Hours, Gross/Net Weight is 129.0 / 112.2 pounds respectively.
Image is attached
Do reply me If you like it.
Last edited by Jon; 08-19-2011 at 06:34 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 08-08-2011, 05:50 AM
Workbench
Need ideas for your shop or garage ? Tons of workbenches, advice, and pics here, my SECOND favorite place on the web...
http://www.garagejournal.com/forum/index.php
Mike B
Old 08-08-2011, 08:32 AM
73oldsman's Avatar
Mike B
Thanks for the link! Looks interesting....
