Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Worn Blower Question
Old 01-26-2010, 07:09 AM
345 desoto's Avatar
345 desoto 345 desoto is offline
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Here's something I was thinking about. If the inside of a 6-71 case/rotors has grooves and such, I understand that the efficiency will be down..depending on the degree of "damage". Will raising the drive percentage help to overcome this? As an example, if it's suppose to be putting out 10lbs of boost, but only putting out 7lbs (due to wear), will over driving it a bit more bring it up? I'm not talking about a case/rotors that are shot...or have I got it all wrong?...
