Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge
  #1
Old 11-18-2004, 10:58 PM
fourbyfourblazer's Avatar
fourbyfourblazer fourbyfourblazer is offline
Chopper Builder o<>\o
The Worst Automobile Engines of All Time
Popular Hotrodding has this article that mentions some of the worst motors ever made. What is your pick?
The worst automobile motors ever made
Old 11-18-2004, 11:33 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
stuff'n things'n whatnot
re: The Worst Automobile Engines of All Time
I nominate the ford 255 V8, hollow crankshaft, and 119hp stock then they stuck it in my thunderbird and the 2.3L I4 is useless.
Old 11-19-2004, 03:46 AM
Hippie's Avatar
Hippie Hippie is offline
They forgot to mention the first Chevy V-8's.............. No boys and girls, put away the tar and feathers, I'm not bad mouthing the '55 small block Chevy!!!! They built a V-8 from 1917 to 1919 and it was an absolute disaster. It was SO bad it took 'em almost 40 years to get up the nerve to try again. BUT it was worth the wait.
Old 11-19-2004, 03:57 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 4
Hyundia Pony and Stellar 4 cylinder.............made in 84-87......still used points, heads cracked................piece of crap.
The Vega motors also stunk............the cylinder inserts dropped down into the aluminum block causing the head gaskets not to seal anymore. A friends car did this after 29000 miles. I fixed it with a big flat bastard file across the block....
and, you thought that I was gonna say....HEMI
Old 11-19-2004, 04:48 AM
Restore60s's Avatar
Restore60s Restore60s is offline
Engines
The GM HT4100. Came with a warning label explaining coolant leaks and using stop leak tabs in it. And not to forget the first few North Star engines with their bottom end oil leak that required you to pull the engine to fix it.
Old 11-19-2004, 04:59 AM
tbirdscott's Avatar
HEY! my first car was an 87 hyundai stellar! hands down the best car I've ever owned and the only one I regret selling. Had it a little less than a year, gave it fresh plugs and filters and drove the snot out of it had 387 000 km on it when I sold it. Found it a few years later in an autowrecker with 435 000 km on it and it was there because it was t-boned. Also experienced an 85 pony they are crap! different engine from the stellar and practically had to push it up hills so no arguments there...
Old 11-19-2004, 07:16 AM
coldknock's Avatar
coldknock coldknock is offline
Oldsmobile 350 diesel.
Larry
Old 11-19-2004, 07:27 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Wow, that is a great list of disasters. Still I think the Caddy 8-6-4 has to be the poster child for the "Just because you have an ME degree, it doesn't mean you can't be a consummate imbecile" club.
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
Larry
I'm currently re-converting one of these back to gasoline operation for an S-10 project.
Even when these diesels ran good they lacked throttle response and power, I had one in an '82 Olds Delta 88 and swapped it out for a gas 350.
Old 11-19-2004, 07:41 AM
coldknock's Avatar
I guess the stout bottom end is at least one redeeming quality.
Larry
Old 11-19-2004, 07:52 AM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
They forgot to put the Pontiac 301, Ford 255, the early Ford 3.8 and I would have put the Chevy 307 on their list.
Old 11-19-2004, 11:28 AM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
No celebrities for presidency!
 ChevelleSS_LS6's barnstar
Wiki Edits: 3
Larry
convert one back to gas, put a lightweight crank in it, and you have a wicked base for a racing engine. The reinforced block makes it capable of withstanfding abuse
in stock form, pos
Old 11-19-2004, 12:32 PM
bowtiebabe72's Avatar
bowtiebabe72 bowtiebabe72 is offline
Microwaving kitties? bad!
The 307 wasn't that bad man. Definately not bad enough to warrant being on the worst engines ever list.
My nova had a 307, ran fine....blew a little smoke and whatnot but was and probably still is reliable. The only reason I got rid of it was simply the fact that I had cheap access to a 350 and wanted a bit more power and an easier time getting aftermarket parts.
Old 11-19-2004, 12:44 PM
crazygutgut's Avatar
crazygutgut crazygutgut is offline
I wanted an egg-salad sandwich
My dad has a caddy with the
CADILLAC V8-6-4
you can diasable the "6-4" part and make it run really nice as an "8"
How about the 3cyl engines they stuck in the first generation chevy sprint?
Old 11-19-2004, 01:37 PM
schnitz's Avatar
schnitz schnitz is offline
I fixed it until it broke....
 schnitz's barnstar
Wiki Edits: 43
My wife had one of those in her '88 Sprint. It was bad, but the 267 Chevy was a lot worse. I'm also with Lindsey on the 307 deal. Not bad engines, just down on power compared to 350s and decently maintained 305s.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
