Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge
  #1
Old 05-09-2008, 12:11 AM
BMM BMM is offline
Worst feeling ever
Doesn't it suck when you try to fix and improve your car, and you end up screwing something else up?
Especially when it's your only ride. Loads of fun.
Old 05-09-2008, 01:16 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 113
re: Worst feeling ever
It sucks now, but tomorrow it'll be the stuff that your experience is made of.
Later, Mikey
BE different....ACT normal.
Old 05-09-2008, 05:03 AM
speedydeedy speedydeedy is offline
31 five window
You got it Mikey. My dad always told me "The only man who does nothing wrong is the man who does nothing". So keep on trying and keep on learning.
Old 05-09-2008, 05:04 AM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Build them like you like them
Mikey is right.Welcome to hot rodding.
Old 05-09-2008, 05:27 AM
poncho62's Avatar
poncho62 poncho62 is online now
Moderator
 poncho62's barnstar
Wiki Edits: 4
I've been doing nothing wrong for a while now.........
Old 05-09-2008, 06:11 AM
schnitz's Avatar
schnitz schnitz is offline
I fixed it until it broke....
 schnitz's barnstar
Wiki Edits: 43
My dad always says that if you don't screw up, you aren't trying hard enough. I know I'm plenty trying.....
In a while, Chet.
It's not what you take with you when you leave, it's what you leave behind you when you go.
Old 05-09-2008, 06:21 AM
killerformula's Avatar
killerformula killerformula is offline
Moderator
Yeah it sure does! These other guys are right, you'll use it to your advantage next time you encounter a problem.
I found, however, that I make the most dumb mistakes when I'm working on the car stressed out or under some kind of constraint (time or other). Whenever possible take the time to preplan and think about an issue you haven't encountered before. This board is a great resource.
Best of luck-
K
Old 05-09-2008, 08:04 AM
428ho 428ho is offline
Doesn't it suck when you try to fix and improve your car, and you end up screwing something else up?[quote]
[QUOTE=speedydeedy]You got it Mikey. My dad always told me "The only man who does nothing wrong is the man who does nothing". So keep on trying and keep on learning.
Hmmm, based on that...
I try to do everything, does that make everything I do wrong? Sure seems that way sometimes.
Old 05-09-2008, 09:31 AM
wedgehead63's Avatar
wedgehead63 wedgehead63 is offline
I especially like it when you get something nice (paint buffing,sanding,tightening something) and try for a little nicer or tighter, and you *%#^%@ it up. All the time ignoring the inner voice that says "get away from it, you idiot!" I have resorted to actually telling myself these words out loud. Sometimes I even listen to myself.
Old 05-09-2008, 10:52 AM
Yep, I tell myself; kiss, kiss. "Keep It Simple Stupid"
Old 05-09-2008, 03:04 PM
sprecher48's Avatar
sprecher48 sprecher48 is offline
Oddo nut
 sprecher48's barnstar
Location: sunny south(maybe rainy,haven't looked outside today) florida
re; worst feeling ever
I really can't speak for these other guys,I,myself never,ever make mistooks! Tom
Old 05-09-2008, 09:00 PM
dough88 dough88 is offline
Keep breakin' parts, keep breakin' tools, you'll keep learnin'. One little piece of advice, if you think you broke a tranny, pull your differential cover and take a look before you pull the tranny. That's my latest stupid mistake
Old 05-09-2008, 09:05 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
OK ... you knew that someone would ask this eventually ...
What did you do?
Maybe you can save someone else from doing the same thing.
Old 05-09-2008, 09:10 PM
boatbob2 boatbob2 is offline
boatbob2
mistakes.......
Hi,when youre stressed out,walk away,cool off then get back in the game and kick a-s,about 20 years ago,i built an aluminum airplane (real one)lots of times i got frustrated,so id walk away from it,it took 4 1/2 years,but i finished it,and it flew great 137 mph on 85 horsepower !!! no,i didnt design it,i built it from plans,sheet aluminum and lots of rivets. didnt give myself time to make mistakes,when youre flying shoulda,coulda , didnt,can get you killed.
Old 05-10-2008, 04:20 PM
BMM BMM is offline
What did you do?
I swapped my valve covers, becuase the old ones were leaking and ugly anyway.
After I did that, I developed a major smoking issue to the point I couldnt breathe inside my car. On the plus side, after 6 hours of cleaning and searching like a moron, I noticed something that made me rather annoyed...
The 3rd plug back on both sides were loose enough to move almost half an inch side to side....And I had recently had a tune-up done at a shop, including plugs.
While we are on the topic, the smoke as since stopped since I tightened up the plugs...My dad says it was probably just spilt oil on the headers, but i ran the car for at least an hour total to try and burn it off, and there was no more oil spilling on them. Could the white smoke have been coming through the incredibly loose plug holes?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Worst feeling ever"
Worst case scenerio - 350 Power question BMM Engine 3 04-24-2007 05:16 PM
Feeling body work tip. MARTINSR Body - Exterior 8 05-29-2006 10:39 AM
What Is The Worst Christmas Gift You've Ever Recieved? Ghetto Jet Off-Topic 74 12-22-2005 06:50 PM
The Worst Automobile Engines of All Time fourbyfourblazer Hotrodders' Lounge 75 12-15-2004 06:41 PM
What's your worst accident? k2mooch Hotrodders' Lounge 11 10-07-2003 10:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
